ConnectorManager is null when object has connectors.
mhillis
mhillis
Good Moring everyone.
I've got a bit of a loopy issue that's frustrating me a little bit.  I've got an MEP Model, in this case, a mechanical object.  When I do the following..
Element e = myMechObject;
if (e is FamilyInstance)
   FamilyInstance fi = e as FamilyInstance;
   if (fi.MEPModel != null)
      ConnectorSetIterator csi = fi.MEPModel.ConnectorManager.Connectors.ForwardIterator();
      //Do stuff with csi.
I get a 'null' value for my ConnectorSetIterator.  Here's the thing, the object HAS connectors and the object is being loaded as far as I can see.  I've put a watch on fi.Name.Symbol and it shows as the mech object that I'm working with, however; I've also confirmed that the fi.MEPModel.ConnectorManager does return null on it's own.  It shouldn't though.
Anyone have any idea what might be causing the ConnectorManager to be getting a null value?  I've attached a sample mech object that replicates this issue.
Dear mhillis,
I also check this family and i also get same issue. But for alternate solution you can do like..
foreach(Connector con in (elm as FamilyInstance).MEPModel.ConnectorManager.Connectors.Cast<Connector>())
   / / Do your Stuff
mhillis
@BholaDev wrote:
Dear mhillis,
   / / Do your Stuff
Bhola dev, thanks for the reply, however; tha doesn't appear to work.  As I mentioned in my first post, for some reason, the actual ConnectorManager of the object is returning 'null', so the example you posted to try won't work I feel.
I did try it to no avail.
Dear mhillis,
I am getting connector using
   / / Do your Stuff
Please see attached files.
