Connect pipes
Connect pipes
Message 1 of 11
Connect pipes
I want to connect two pipes similar to trim tool in revit.
How do I programatically call trim command.
Thanks & Regards
Replies (10)
Message 2 of 11
jeremytammik
Message 3 of 11
Diidn't understand what was googled for me.
A simple question I have two pipes pipe1 and pipe2
Neither of them works successfully to connect two pies:
1. doc.Create.NewElbowFitting(c1end,c2start);
2.c1end.ConnectTo(c2start);
c1end is the connctor of pipe1 and c2start is the connector of pipe2
Message 4 of 11
jeremy_tammik
What happens if you connect them manually in the user interface?
Message 5 of 11
They simply get connected.
Message 6 of 11
jeremy_tammik
Good. Your solution 2. should produce the same result.
Message 7 of 11
No it does not.
Message 9 of 11
The image below will clarify things:
Tried:
try
Command.doc.Create.NewElbowFitting(c1end, c2start);
catch (Exception sdq)
MessageBox.Show(sdq.Message.ToString());
Tried Thsi:
try
 tried this
try
But it creates the fittings between pipes in one place but not at the other.
Message 10 of 11
Where you able to solve this at any point? I'm having the exact same problem and cannot find a solution.
Message 11 of 11
Jes_Gonzalez
Any updated information on this would be greatly appreciated. I'm going down the same road.
