computeReferences?
computeReferences?
computeReferences?
So I have written this function to prompt the user to select a face:
        Public Function SelectSingleFace() As Face
            Dim selectedReference As Reference = _uidoc.Selection.PickObject(ObjectType.Face, "Select Face")
            Dim e As Element = _uidoc.Document.GetElement(selectedReference.ElementId)
            Return (TryCast(e.GetGeometryObjectFromReference(selectedReference), Face))
        End Function
Which generally works ok, however the returned face does not compute references. ie.
SelectSingleFace.Reference = nothing
Is there a way to turn on computeReferences prior to calling PickObject?
Brett
jeremytammik
No, not that I am aware of.
You can query the picked element for its geometry after the pick completes, and specify compute references in that call.
Cheers, Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
