Command Interface Parameters
owenmerrick
owenmerrick
Is it is possible to implement user interface input similar to wall interface shown above in a custom command? (The green bar which appears during built-in commands, allowing users to set parameters which persist between instances of the command). Does this interface component have a name?  I'm not sure what to search for in the samples or documentation.
Any insight would be great, Thanks,
Owen
jeremytammik
Dear Owen,
Thank you for your query.
No, sorry, I do not believe that is possible.
As far as I know, all possible custom user interface options are demonstrated by the ADN Revit API Labs Training Material:
https://github.com/ADN-DevTech/RevitTrainingMaterial
https://github.com/ADN-DevTech/RevitTrainingMaterial/tree/master/Labs/2_Revit_UI_API
Look at the documentation and lab instructions:
https://github.com/ADN-DevTech/RevitTrainingMaterial/tree/master/Labs/2_Revit_UI_API/DocsCS
As said, I do not believe what you are asking for is included.
Sorry about that.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
owenmerrick
Hi Jeremy,
Thanks for confirming.
I really like this style of interface, which appears only during the command, allows the input of a few relevant parameters, and maintains the last set value between executions of the command.  I also prefer to use the built-in interface elements where possible for consistency, so I was hoping this was an option.
Not a big deal, there are certainly other ways to get there.
Thanks for the UI references, I'll have a look.
Best,
Owen
