ColorSelectionDialog - API Error, or am I doing it wrong?
orosztamas
orosztamas
When I click cancel on an API called ColorSelectionDialog, I get RGB(0,0,0) color as "SelectedColor" property, when I would expect nothing. (It is also RGB(0,0,0), if I select a color, then I hit Cancel)l Am I doing it wrong, or is this the expected behavior?
jeremytammik
TheColorSelectionDialog.Show method returns an ItemSelectionDialogResult object that enables you to determine whether the dialogue was cancelled or confirmed:
https://www.revitapidocs.com/2020/8f9ca1fe-744c-924a-5e83-31e9d730065d.htm
  • Confirmed -- The user selected one or more item(s) from the prompted dialog and confirmed the selection. The selected item(s) are available from the dialog interfaces.
  • Canceled -- The user canceled the prompted dialog. No selected item(s) are available from the dialog interfaces.
Does that not solve the problem you describe?
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
orosztamas
I just received an answer from @jeremytammik  ❤️ ❤️ 😄 😄
Yes, thank you! I wasn't aware of the returned object. This solved my problem.
jeremytammik
Thank you for your appreciation.
Well, a quick look at the documentation can save you hours of work and frustration.
And others, as well.
Please take heed.
Jeremy Tammik
The Building Coder
