Announcements
Collect all column instances
Ali.sadeghi.h1994
Ali.sadeghi.h1994
Hi. How can I collect all existed column instances in my model?
RPTHOMAS108
Like you collect all things FilteredElementCollector
'Existed' or 'Existing'?
It is impossible to tell if it 'existed' apart from comparing with older models.
What do you mean by 'existing':
This column exists in the model and so it is existing, it is therefore it exists?
This column is built on a phase previous to the current one?
ElementPhaseStatusFilter is a slow filter so combine it with ElementCategoryFilter for columns. You could use a class filter but then you would still have to distinguish the category since both would be FamilyInstances. So in this instance a ElementCategoryFilter seems the best quick filter.
jeremy_tammik
Retrieve column family instances sorted as in schedule:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/CmdCollectorPer...
Retrieve column instances:
  /// <summary>
  ///   Return a sorted list of all structural columns.
  ///   The sort order is defined by ColumnMarkComparer
  ///   as requested to to replicate the graphical column
  ///   schedule sort order with C# in
  ///   https://forums.autodesk.com/t5/revit-api-forum/replicate-graphical-column-schedule-sort-order-with-c/m-p/9105470
  /// </summary>
  private List<FamilyInstance> GetSortedColumns(Document doc)
    var colums
      = new FilteredElementCollector(doc)
        .WhereElementIsNotElementType()
        .OfCategory(BuiltInCategory.OST_StructuralColumns)
        .OfClass(typeof(FamilyInstance))
        .Cast<FamilyInstance>()
        .ToList();
    colums.Sort(new ColumnMarkComparer());
    return colums;
Ali.sadeghi.h1994
That was just a grammatical mistake. Thanks for your guides.
Ali.sadeghi.h1994
thanks a lot.
