Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Collect all column instances
4 REPLIES 4
Ali.sadeghi.h1994
375 Views, 4 Replies
Hi. How can I collect all existed column instances in my model?
Tags (3)
Labels (2)
4 REPLIES 4
Like you collect all things FilteredElementCollector
'Existed' or 'Existing'?
It is impossible to tell if it 'existed' apart from comparing with older models.
What do you mean by 'existing':
This column exists in the model and so it is existing, it is therefore it exists?
This column is built on a phase previous to the current one?
ElementPhaseStatusFilter is a slow filter so combine it with ElementCategoryFilter for columns. You could use a class filter but then you would still have to distinguish the category since both would be FamilyInstances. So in this instance a ElementCategoryFilter seems the best quick filter.
Retrieve column family instances sorted as in schedule:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/CmdCollectorPer...
Retrieve column instances:
  /// <summary>
  ///   Return a sorted list of all structural columns.
  ///   The sort order is defined by ColumnMarkComparer
  ///   as requested to to replicate the graphical column
  ///   schedule sort order with C# in
  ///   https://forums.autodesk.com/t5/revit-api-forum/replicate-graphical-column-schedule-sort-order-with-c/m-p/9105470
  /// </summary>
  private List<FamilyInstance> GetSortedColumns(Document doc)
    var colums
      = new FilteredElementCollector(doc)
        .WhereElementIsNotElementType()
        .OfCategory(BuiltInCategory.OST_StructuralColumns)
        .OfClass(typeof(FamilyInstance))
        .Cast<FamilyInstance>()
        .ToList();
    colums.Sort(new ColumnMarkComparer());
    return colums;
That was just a grammatical mistake. Thanks for your guides.
thanks a lot.
