Closing modeless when all documents are closed
SONA-ARCHITECTURE
SONA-ARCHITECTURE
Based on the Sdk sample called "ModelessForm_ExternalEvent", I run a modeless form to do some stuff
I'd like to close my modeless form when all documents are closed.
I've tried to do this but it seems that when I'm opening more than 2 documents, DoCumentClosed events do not raise.
What's wrong with my code please?
public class Main : IExternalApplication
        // class instance
        internal static Main thisApp = null;
        // ModelessForm instance
        private RoutingManagerModelessForm m_RoutingManagerForm;
        public static Application m_App;
        #region external application public methods
        /// <summary>
        /// Called when Revit starts up
        /// </summary>
        /// <param name="application"></param>
        /// <returns></returns>
        /// <exception cref="System.NotImplementedException"></exception>
        public Result OnStartup(UIControlledApplication application)
            // Initialize whole plugin's user interface.
            var ui = new SetupInterface();
            ui.Initialize(application);
            thisApp = this;
            m_RoutingManagerForm = null;
            return Result.Succeeded;
        #endregion
        /// <summary>
        /// Called when Revit shutdown
        /// </summary>
        public Result OnShutdown(UIControlledApplication application)
            if (m_RoutingManagerForm !=null && m_RoutingManagerForm.IsVisible)
                m_RoutingManagerForm.Close();
        #region private methods
        /// <summary>
        ///   This method creates and shows a modeless dialog, unless it already exists.
        /// </summary>
        /// <remarks>
        ///   The external command invokes this on the end-user's request
        /// </remarks>
        public void ShowForm(ExternalCommandData cD)
            ExternalCommandData commandData = cD;
            m_App = cD.Application.Application;
            try
                // If we do not have a dialog yet, create and show it
                if (m_RoutingManagerForm == null || WindowHelper.IsDisposed(m_RoutingManagerForm))
                    // We give the objects to the new dialog;
                    // The dialog becomes the owner responsible fore disposing them, eventually.
                    m_RoutingManagerForm = new RoutingManagerModelessForm(commandData);
                    m_RoutingManagerForm.myThisApp = this;
                    m_RoutingManagerForm.Show();
                    m_App.DocumentClosed += new EventHandler<DocumentClosedEventArgs>(OnDocumentClosed);
            #region catch and finally
            catch (Exception ex)
                ess_routing.Log.WriteDebug("EE_UpdateForm_ViewActivatedMethod" + Environment.NewLine + ex.Message + Environment.NewLine + ex.InnerException, true);
            finally
            #endregion
        private void OnDocumentClosed(object sender, DocumentClosedEventArgs e)
            System.Windows.Forms.MessageBox.Show("Documents en cours:" + m_App.Documents.Size);
            if (m_RoutingManagerForm != null)
                m_RoutingManagerForm.WakeUp();
                if (m_App.Documents.Size == 0)
                m_App.DocumentClosed -= new EventHandler<DocumentClosedEventArgs>(OnDocumentClosed);
Pierre NAVARRA
SONA-Architecture.
http://www.sona-architecture.com
https://fr.linkedin.com/in/pierre-navarra-62032a107
jeremy_tammik
Very tricky to diagnose on sight. Maybe you are registering some event handlers on the wrong objects? I struggled with similar issues in various cases, and it was always a question of cleaning up and centralising. The fact that the DocumentClosed handler is not called at a certain point would seem to confirm this suspicion. I would suggest using standard debugging approaches:
  • divide and conquer
  • remove functionality step by step until it works
  • start from scratch with a working system and add functionality step by step until it stops working
Standard debugging tactics.
SONA-ARCHITECTURE
Thx Jeremy
I finally put the += new EventHandler on OnStartup instead of OnShutdown function and it works
            thisApp = this;
            m_UIControlledApplication = application;
            application.ControlledApplication.DocumentClosing += new EventHandler<DocumentClosingEventArgs>(CheckClosingProject);
Pierre NAVARRA
SONA-Architecture.
jeremy_tammik
Yes. that makes sense. Congratulations on solving it.
