clicking a button inside tab control/ tab page - revit form
Or.levi
Or.levi
hey everyone,
i am trying too use a tabControl panel  to put multiple  features in a single form.
how can i make a button inside a tab clickable? it seems as if the button is not active when its being clicked from inside its parent tab.
how can i make the button  active from inside the tab container?
notes:
i tryied to place a call for the button inside the tabPage, but then - when i clicked the button nothing happened, but when i clicked somewhere random inside the tab itself the button activity started.
buttons decleration + tabcontrol decleration:
   // a button to add the associated views to the right listbox (listbox2)
        private void button1_Click(object sender, EventArgs e)
            listBox2.Items.Clear();
            selectedItemText = listBox1.SelectedItem.ToString();
            selectedItemIndex = listBox1.SelectedIndex;
            foreach(Level lev in levels)
                if(lev.Name == selectedItemText)
                    pickedLevel = lev;
            foreach(Element view in views)
                View v = view as View;
                if (v.GenLevel != null)//check if the view is indeed a level
                    if (v.ViewType == ViewType.CeilingPlan && v.GenLevel.Name == pickedLevel.Name)//check if the plan is cielling, and if it has the same level as chosen
                        listBox2.Items.Add(v.Name);
            dataBindings();
// set the listbox1  back
      private void dataBindings()
            listBox1.DataSource = null;
            listBox1.DataSource = levelNames;// string list
    // button to clear the right listbox
        private void button2_Click(object sender, EventArgs e)
            dataBindings();
// the tab decleration--> what goes here?
     private void tabPage1_Click(object sender, EventArgs e)
thanks!
Or.levi
hey,
turns out that for some reason when i created new buttons and put them directly onto the tab it worked!
thanks !
