Circular Reference error while setting WallType
harilalmn
harilalmn
Hi All,
I was working with Stacked Walls. It was a simple attempt to change the WallType of all wall instances to the default StackedWall. However this throws an error saying,
"There is a circular chain of references among the highlighted elements."
Here is my code (I am doing this in Macro environment)
public void Test()
    UIDocument uidoc = ActiveUIDocument;
    Document doc = uidoc.Document;
    WallType wt = null;
    ICollection<Element> wallTypesInThisDoc = new FilteredElementCollector(doc)
        .OfClass(typeof(WallType))
        .Where(
            w => w.get_Parameter(BuiltInParameter.SYMBOL_FAMILY_NAME_PARAM).AsValueString().Equals("Stacked Wall")
        .ToList();
    if (wallTypesInThisDoc.Count > 0)
        wt = wallTypesInThisDoc.First() as WallType;
    else
        return;
    List<Wall> allWalls = new FilteredElementCollector(doc).OfClass(typeof(Wall)).Select(w => (Wall)w).ToList();
    using (Transaction tr = new Transaction(doc, "Set Wall Type"))
        try
            tr.Start();
            foreach (Wall wall in allWalls)
                wall.WallType = wt;
            tr.Commit();
            uidoc.RefreshActiveView();
        catch (Exception e)
            TaskDialog.Show("Error", e.Message);
How to resolve this?
jeremy_tammik
Sorry, I don't know what might be the problem.
However, you can very easily significantly shorten, simplify and optimise your code like this:
    public void Test(Document doc)
      WallType wt
          .FirstElement() as WallType;
      FilteredElementCollector allWalls
          .OfClass(typeof(Wall));
      using (Transaction tr = new Transaction(doc))
        try
          tr.Start("Set Wall Type");
            wall.WallType = wt;
          tr.Commit();
        catch (Exception e)
Please avoid ToList and ToElements and suchlike when you can (which is almost always). It is a waste of processing time and memory both:
harilalmn
Thankyou Jeremy, for the concise and neat version of the code. I was, infact having a big round-about, LOL...!
Well, now, coming to the circular reference, I have some generic walls there. These are of family 'Basic Wall'. I am trying to change them to Stacked Walls. But I get the error saying;
"There is a circular chain of references among the highlighted elements"
RPTHOMAS108
This is something an end user would occasionally face so there is an automated API solution along those lines I expect.
"There is a circular chain of references among the highlighted elements" when modifying a stacked wa...
It is rarely the case you can globally change multiple types without relationships between instances using those types being impacted. In this case it seems that it has something to do with the generation of the wall joins.
I'm unclear on if the existing wall type is stacked and/or the newly assigned one is. One suggestion is to (as an intermediate step) change them to basic walls first. Another is to unjoin walls which can be done in the API via the WallUtils class.
harilalmn
Let me explain the scenario in detail.
I am trying to change these wall to stacked walls. There are many rooms in the file. Each room has stacked walls as boundary based on many design rules. These stacked wall types are brought in from a 'library of stacked walls' (a .rvt file). But before changing the wall types for a room, the walls which run continuously beyond the room boundary are to be split at joints. For that I have the following method;
public static void SplitWalls(Room room)
            if (room != null)
                List<Wall> roomWalls = room.GetWalls();
                Queue<Wall> walls = new Queue<Wall>();
                roomWalls.ForEach(w => walls.Enqueue(w));
                using (Transaction t = new Transaction(GlobalSettings.Doc, "wall spliting"))
                    t.SetFailureHandlingOptions(t.GetFailureHandlingOptions().SetFailuresPreprocessor(new AutoDetachOrDeleteFailurePreprocessor()));
                    t.Start();
                    while (walls.Count > 0)
                        Wall currentWall = walls.Dequeue();
                        //Get all walls intersecting this wall
                        List<XYZ> intersectionPoints = new List<XYZ>() { currentWall.StartPoint(), currentWall.EndPoint() };
                        intersectionPoints.AddRange(currentWall.GetIntersections());
                        // order intersection points by distance from start point
                        intersectionPoints = intersectionPoints.OrderBy(p => currentWall.StartPoint().DistanceTo(p)).ToList();
                        // Remove points that are closer by tolerence or overlpping
                        List<XYZ> overlappingPoints = new List<XYZ>();
                        for (int i = 0; i < intersectionPoints.Count - 1; i++)
                            XYZ p1 = intersectionPoints[i];
                            XYZ p2 = intersectionPoints[i + 1];
                            if (p1.DistanceTo(p2) <= GlobalSettings.Doc.Application.ShortCurveTolerance)
                                overlappingPoints.Add(p2);
                        intersectionPoints.RemoveAll(p => overlappingPoints.Contains(p));
                        List<Wall> newWalls = new List<Wall>() { currentWall };
                        // create copies of currentWall
                        for (int i = 0; i < intersectionPoints.Count - 2; i++)
                            Wall newWall = GlobalSettings.Doc.GetElement(ElementTransformUtils.CopyElement(
                                GlobalSettings.Doc,
                                currentWall.Id,
                                new XYZ(0, 0, 0)
                            ).FirstOrDefault()) as Wall;
                            newWalls.Add(newWall);
                        // set wall curves
                            Wall thisWall = newWalls[i];
                            XYZ sp = intersectionPoints[i];
                            XYZ ep = intersectionPoints[i + 1];
                            Curve wallCurve = thisWall.GetCurve();
                            double p1 = wallCurve.Project(sp).Parameter;
                            double p2 = wallCurve.Project(ep).Parameter;
                            wallCurve.MakeBound(p1, p2);
                            thisWall.SetCurve(wallCurve);
                            if (i > 0) walls.Enqueue(thisWall);
                    t.Commit();
Here is the set curve method:
public static void SetCurve(this Wall wall, Curve curve)
    if (wall.IsValidObject == false || wall == null || curve == null) return;
    using (Transaction t = new Transaction(wall.Document, "Set Curve"))
        if (RRAPGlobal.Doc.IsModifiable == false)
            t.Start();
        try
            WallUtils.DisallowWallJoinAtEnd(wall, 0);
            WallUtils.DisallowWallJoinAtEnd(wall, 1);
            ((LocationCurve)wall.Location).Curve = curve;
            WallUtils.AllowWallJoinAtEnd(wall, 0);
            WallUtils.AllowWallJoinAtEnd(wall, 1);
        catch (Exception e)
        if (t.HasStarted())
            t.Commit();
Here is the set wall type method;
private void _setWallType(WallType wallType)
    // Check if wall is valid
    if (this.Wall == null) return;
    if (wallType == null) return;
    using (Transaction t = new Transaction(GlobalSettings.Doc, "Set wall type"))
        t.Start();
        FailureHandlingOptions options = t.GetFailureHandlingOptions();
        options.SetFailuresPreprocessor(new CircularChainWarningSwallower());
        t.SetFailureHandlingOptions(options);
        try
            if (wallType.IsValidObject)
                try
                    WallType wallTypeToSet = new FilteredElementCollector(GlobalSettings.Doc)
                    .Cast<WallType>()
                    .Where(x => x.Name == wallType.Name)
                    .FirstOrDefault();
                    if (wallTypeToSet == null)
                        if (DocumentQueries.ElementTypeExists<WallType>(GlobalSettings.WallLibrary, wallType.Name) == false)
                            return;
                        CopyPasteOptions copyPasteOptions = new CopyPasteOptions();
                        copyPasteOptions.SetDuplicateTypeNamesHandler(new DuplicateTypeNamesHandler());
                        wallTypeToSet = GlobalSettings.Doc.GetElement(
                        ElementTransformUtils.CopyElements(
                            new List<ElementId>() { wallType.Id },
                            GlobalSettings.Doc,
                            Transform.Identity,
                            copyPasteOptions
                        ).First()) as WallType;
                    if (wallTypeToSet != null)
                        this.WallType = wallTypeToSet;
                        this.Wall.WallType = this.WallType;
                catch (Exception er)
            else
        catch (Exception e)
            TaskDialog.Show("Error setting wall type", e.Message);
        t.Commit();
Following are the errors
