Let me explain the scenario in detail.
I am trying to change these wall to stacked walls. There are many rooms in the file. Each room has stacked walls as boundary based on many design rules. These stacked wall types are brought in from a 'library of stacked walls' (a .rvt file). But before changing the wall types for a room, the walls which run continuously beyond the room boundary are to be split at joints. For that I have the following method;
public static void SplitWalls(Room room)
if (room != null)
List<Wall> roomWalls = room.GetWalls();
Queue<Wall> walls = new Queue<Wall>();
roomWalls.ForEach(w => walls.Enqueue(w));
using (Transaction t = new Transaction(GlobalSettings.Doc, "wall spliting"))
t.SetFailureHandlingOptions(t.GetFailureHandlingOptions().SetFailuresPreprocessor(new AutoDetachOrDeleteFailurePreprocessor()));
t.Start();
while (walls.Count > 0)
Wall currentWall = walls.Dequeue();
//Get all walls intersecting this wall
List<XYZ> intersectionPoints = new List<XYZ>() { currentWall.StartPoint(), currentWall.EndPoint() };
intersectionPoints.AddRange(currentWall.GetIntersections());
// order intersection points by distance from start point
intersectionPoints = intersectionPoints.OrderBy(p => currentWall.StartPoint().DistanceTo(p)).ToList();
// Remove points that are closer by tolerence or overlpping
List<XYZ> overlappingPoints = new List<XYZ>();
for (int i = 0; i < intersectionPoints.Count - 1; i++)
XYZ p1 = intersectionPoints[i];
XYZ p2 = intersectionPoints[i + 1];
if (p1.DistanceTo(p2) <= GlobalSettings.Doc.Application.ShortCurveTolerance)
overlappingPoints.Add(p2);
intersectionPoints.RemoveAll(p => overlappingPoints.Contains(p));
List<Wall> newWalls = new List<Wall>() { currentWall };
// create copies of currentWall
for (int i = 0; i < intersectionPoints.Count - 2; i++)
Wall newWall = GlobalSettings.Doc.GetElement(ElementTransformUtils.CopyElement(
GlobalSettings.Doc,
currentWall.Id,
new XYZ(0, 0, 0)
).FirstOrDefault()) as Wall;
newWalls.Add(newWall);
// set wall curves
Wall thisWall = newWalls[i];
XYZ sp = intersectionPoints[i];
XYZ ep = intersectionPoints[i + 1];
Curve wallCurve = thisWall.GetCurve();
double p1 = wallCurve.Project(sp).Parameter;
double p2 = wallCurve.Project(ep).Parameter;
wallCurve.MakeBound(p1, p2);
thisWall.SetCurve(wallCurve);
if (i > 0) walls.Enqueue(thisWall);
t.Commit();
Here is the set curve method:
public static void SetCurve(this Wall wall, Curve curve)
if (wall.IsValidObject == false || wall == null || curve == null) return;
using (Transaction t = new Transaction(wall.Document, "Set Curve"))
if (RRAPGlobal.Doc.IsModifiable == false)
t.Start();
try
WallUtils.DisallowWallJoinAtEnd(wall, 0);
WallUtils.DisallowWallJoinAtEnd(wall, 1);
((LocationCurve)wall.Location).Curve = curve;
WallUtils.AllowWallJoinAtEnd(wall, 0);
WallUtils.AllowWallJoinAtEnd(wall, 1);
catch (Exception e)
TaskDialog.Show("Error", e.Message);
if (t.HasStarted())
t.Commit();
Here is the set wall type method;
private void _setWallType(WallType wallType)
// Check if wall is valid
if (this.Wall == null) return;
if (wallType == null) return;
using (Transaction t = new Transaction(GlobalSettings.Doc, "Set wall type"))
t.Start();
FailureHandlingOptions options = t.GetFailureHandlingOptions();
options.SetFailuresPreprocessor(new CircularChainWarningSwallower());
t.SetFailureHandlingOptions(options);
try
if (wallType.IsValidObject)
try
WallType wallTypeToSet = new FilteredElementCollector(GlobalSettings.Doc)
.OfClass(typeof(WallType))
.Cast<WallType>()
.Where(x => x.Name == wallType.Name)
.FirstOrDefault();
if (wallTypeToSet == null)
if (DocumentQueries.ElementTypeExists<WallType>(GlobalSettings.WallLibrary, wallType.Name) == false)
return;
CopyPasteOptions copyPasteOptions = new CopyPasteOptions();
copyPasteOptions.SetDuplicateTypeNamesHandler(new DuplicateTypeNamesHandler());
wallTypeToSet = GlobalSettings.Doc.GetElement(
ElementTransformUtils.CopyElements(
new List<ElementId>() { wallType.Id },
GlobalSettings.Doc,
Transform.Identity,
copyPasteOptions
).First()) as WallType;
if (wallTypeToSet != null)
this.WallType = wallTypeToSet;
this.Wall.WallType = this.WallType;
catch (Exception er)
else
catch (Exception e)
TaskDialog.Show("Error setting wall type", e.Message);
t.Commit();
Following are the errors
