Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Checking if a door opens the same direction as the path of travel
2 REPLIES 2
iliasmitmail
563 Views, 2 Replies
I am trying to finde a way to analyze the Problem mentioned in the title. Is there maybe already a method to do this?
Otherwise I have the following idea:
As far as I know getting Directions in Revit means that I will get a Vector like this (x,y,z).
First of all I need to get the Direction in which the door opens. Than according to the start and endpoint of my Path of Travel I can say whether my Directions on the x- and y-axes are positiv or negative (which way they are facing). Now I can check those with the Direction of my Door. If I devide the two directions with each other there should be a positiv number as a result if they face the same direction.
Maybe the following picture will help understanding my explenation:
However getting the direction of a door already seems to be a big difficulty.
I am sorry if I did not explain something clearly enough. Using mathimatical vocabulary in english is pretty new to me.
I am very thankfull for your help!!
2 REPLIES 2
I searched the Internet for 'revit api door opening direction':
https://duckduckgo.com/?q=revit+api+door+opening+direction
That returns:
Get a door’s open direction and hinge side
https://adndevblog.typepad.com/aec/2012/06/get-doors-open-direction-and-hinge-side.html
Does that help?
Thank you very much. It was a great help!
Rail Community
