Check the overlapping dimension text
ttnhan1
ttnhan1
I am new to Revit API, I am trying to make an add-in to add the dimension automatically. But some dimension texts overlap. For example here:
I use this function to add a dimension to the grid
 Dimension dim = doc.Create.NewDimension(doc.ActiveView, rowDimLine, rowsArr);
The new dimension have some overlapped text like this:
A dimension has many segments, how can I find which segments (or which text) overlap?
As I researched, I can get the "drag point" of the text by this code:
var firstSegment = dim.Segments.get_Item(0);
XYZ dragPoint = firstSegment.TextPosition;
 However, with one point, I cannot check if that text overlaps other text.
With the dimension' type, I can get the text size but not the text box's width.
var type = doc.GetElement(dim.DimensionType.Id);
double textSize = type.get_Parameter(BuiltInParameter.TEXT_SIZE).AsDouble();
How can get the dimension textbox's width or check which text overlaps?
jeremy_tammik
Well, just checking whether the dimension texts overlap is not that hard, in theory at least:
  • Retrieve all dimensions' text extents
  • Check for collision between the 2D bounding boxes
The first has been discussed here in the past:
Detecting overlapping boxes in 2D is a standard geometric algebra task:
What do you do with that information? Adjusting manually is possible but may be tedious. Automatically removing overlaps is a pretty challenging task, cf.:
ttnhan1
Hi @jeremy_tammik,
Thank you for your response, I tried your suggestion in this post https://forums.autodesk.com/t5/revit-api-forum/the-height-and-width-of-the-dimension-text/m-p/108732...
I tried to get TextNode in onText function. However, I'm not sure when onText is called, It didn't work for my case.
I tried another way (a silly and complex way, I think). I got segments of the dimension and created textNotes with the same font style. I got the text boxes' width and height from textNotes.
ElementId defaultTextTypeId = doc.GetDefaultElementTypeId(ElementTypeGroup.TextNoteType);
TextNoteType type = doc.GetElement(defaultTextTypeId) as TextNoteType;
DimensionType dimType = dimension.DimensionType;
type.get_Parameter(BuiltInParameter.TEXT_FONT).Set(dimType.get_Parameter(BuiltInParameter.TEXT_FONT).Id);
type.get_Parameter(BuiltInParameter.TEXT_SIZE).Set(dimType.get_Parameter(BuiltInParameter.TEXT_SIZE).AsDouble());
type.get_Parameter(BuiltInParameter.TEXT_STYLE_BOLD).Set(dimType.get_Parameter(BuiltInParameter.TEXT_STYLE_BOLD).AsDouble());
type.get_Parameter(BuiltInParameter.TEXT_STYLE_ITALIC).Set(dimType.get_Parameter(BuiltInParameter.TEXT_STYLE_ITALIC).AsDouble());
foreach (DimensionSegment seg in dimension.Segments)
    TextNote note = TextNote.Create(doc, doc.ActiveView.Id, seg.TextPosition, seg.ValueString.Trim(), type.Id);
    newTextNote.Add(note);
Based on the text's width and Text position, I checked which segment's text overlapped and changed the Text Position.
Finally, I remove all created textNotes.
At least, It solved my issue.
I appreciate your help.
jeremy_tammik
Clever idea! Congratulations on achieving a good solution!
