Changing the Font of schedule headers with SetCellStyle
Rockit_for_Revit
Rockit_for_Revit
I have project with hundreds of schedules created with the rows in the headers.
I would like to use the following code to change the font of each of the cells in the headers.
For intHeaderRow As Integer = 0 To intScheduleRowColumnCountHeaderRows
    For intHeaderColumn As Integer = 0 To intScheduleRowColumnCountHeaderColumns
        Dim objTableCellStyle As TableCellStyle = objTableSectionData.GetTableCellStyle(intHeaderRow, intHeaderColumn)
        If Not objTableCellStyle.FontName.Equals(strNewFontName) Then
                                        If objTableSectionData.AllowOverrideCellStyle(intHeaderRow, intHeaderColumn) Then
                                            Dim options As TableCellStyleOverrideOptions = New TableCellStyleOverrideOptions With {
                                                .FontSize = False
                                            objTableCellStyle.FontName = strNewFontName
                                            objTableCellStyle.SetCellStyleOverrideOptions(options)
                                            objTableSectionData.SetCellStyle(intHeaderRow, intHeaderColumn, objTableCellStyle)
            End If
        End If
    Next
Next
This code works well & changes the font, however it does not preserve the size or the boldness of the cell.
The size gets changed to the same as what is set in the schedule appearance header text.
Any ideas?
Kind Regards
David
david_rock
Sorry for the multiple post, site connection issues.
I have solved this now by removing the options.
                                        End If
                                    End If
                                Next
                            Next
Kind Regards
David
