Changing a Cloud Revit Link to Local Revit Link RevitLinkType.LoadFrom
david_rock
david_rock
I would like to change the paths of Revit Linked models from a cloud location to a local path location.
I'm using the following code:
RevitLinkType.LoadFrom(ModelPath, new WorksetConfiguration())
When RevitLinkType is derived from a cloud model I receive:
I receive the error: An internal error has occurred.
When RevitLinkType is derived from a local path the model is reloaded.
Kind Regards
David
jeremytammik
Dear David, I am asking the development team for you... hang on. Cheers, Jeremy (personal link)
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
jeremytammik
Dear David,
Thank you for your patience.
The development team reply:
That's supposed to work. Please submit a complete, minimal, self-contained reproducible case for the development team to reproduce and analyse the problem:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
I don't know if this next suggestion will work, but as a workaround you could try making an ExternalResourceReference object using ExternalResourceReference.CreateLocalResource() and then calling the version of LoadFrom() which takes an ExternalResourceReference instead of a ModelPath.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
david_rock
Thank you,
I tried using:
And it worked....
If objRevitLinkType.IsFromLocalPath Then
    objRevitLinkType.LoadFrom(objRockitLinkItem.objModelPath, Nothing)
Else
    Dim objExternalResourceType As ExternalResourceType = ExternalResourceTypes.BuiltInExternalResourceTypes.RevitLink
    Dim objExternalResourceReference As ExternalResourceReference = ExternalResourceReference.CreateLocalResource(activeDBdoc, objExternalResourceType, objRockitLinkItem.objModelPath, PathType.Absolute)
    objRevitLinkType.LoadFrom(objExternalResourceReference, Nothing)
End If
Thank you very much.
kind Regards
David
