Changes and Additions to the Revit API 2013 to 2017
stever66
Advisor Advisor
stever66
I got tired of searching 4 or 5 different documents for keywords that have been changed.  So I put together a single PDF with all the Changes and Additions to the Revit API from 2013 to 2017.
I assume there is no problem posting this information in one single document, and I hope its helpful to others.
jeremytammik
Dear Steve,
Thank you for doing this!
Are you aware that all of these are also collected in one single place by The Building Coder?
Furthermore, all the source text for The Building Coder blog is available for download on GitHub:
https://github.com/jeremytammik/tbc
Also check out the complete index on GitHub pages:
https://jeremytammik.github.io/tbc/a
I hope you find this useful, and that it helps simplify your future searches.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
stever66
Jeremy:
I've seen your recent posts for changes to the API (maybe the last 2 years), but no, I didn't realize you had them going back as far as 2008.
Thanks for the info.
Dale.Bartlett
Hi Steve,
Not to take anything away from Jeremy's sterling work, but your document will indeed be very helpful. When this Web thing runs out of steam, the hordes will be willing to trade a lot for a real pdf.
Thanks, Dale.
______________
Yes, I'm Satoshi.
jeremytammik
Saved for posterity on The Building Coder:
http://thebuildingcoder.typepad.com/blog/2017/09/adn-xtra-labs-and-api-changes-since-revit-2013.html...
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
