Change pipe diamter before create using api
I want to change the pipe diameter value in red rectangle
help me!
Charles.Piro
the diameter is a parameter of the pipe. Sample :
double dblnewValue = 0.328084; //Value for 100mm
using (Transaction trans = new Transaction(doc))
   trans.Start("modify Diameter");
    _pipe.get_Parameter(BuiltInParameter.RBS_PIPE_DIAMETER_PARAM).Set(dblnewValue);
     trans.Commit();
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
franciscopossetto
Did you find Any solution for this question?
Github:
https://github.com/franpossetto
jeremy_tammik
This discussion is continued in a later thread:
https://forums.autodesk.com/t5/revit-api-forum/set-pipe-diameter-before-select-the-pipetype/m-p/1009...
