Change category of FamilyInstance
gena.bayanov
Observer Observer
gena.bayanov
Observer
Observer
Hello!
Is it possible to programmatically change the category of FamilyInstace?
jeremytammik
No, I believe that is fixed by the family and connot be changed in the individual instance.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
gena.bayanov
Observer
Observer
Thanks you for answer.
But I mean, is it possible to programmatically repeat the same actions as the user interface: Select object, click Edit in-place, click Family categories and parameters and select different category?
jeremytammik
Yes, sure. Please note that you cannot manipulate in-place familes programmatically at all. If it is a standard family, however, you can use the Document.EditFamily method to open the family document for modification, and then reload it into the project again when you are done.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
gena.bayanov
Observer
Observer
Ok. Thanks you!
jeremytammik
My pleasure entirely  🙂
Jeremy Tammik
The Building Coder
