Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Centre point of model
2 REPLIES 2
josenlee34_21
333 Views, 2 Replies
josenlee34_21
Hi all, cannot seem to get the centre point of my model with this code below. Does anyone have a solution of this?
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
namespace REVITAPIFYP
public class CenterPointFinder : IExternalCommand
public Result Execute(
ExternalCommandData commandData,
ref string message,
ElementSet elements)
// Get the active document
Document doc = commandData.Application.ActiveUIDocument.Document;
// Get all elements in the model
FilteredElementCollector collector = new FilteredElementCollector(doc);
ICollection<Element> allElements = collector.ToElements();
// Calculate the center point
XYZ centerPoint = GetCenterPoint(allElements);
// Display the center point (for demonstration purposes)
TaskDialog.Show("Center Point", $"Center Point: {centerPoint}");
return Result.Succeeded;
private XYZ GetCenterPoint(ICollection<Element> elements)
// Initialize variables to calculate the center point
double totalX = 0;
double totalY = 0;
double totalZ = 0;
int count = 0;
// Loop through all elements to calculate the total position
foreach (Element element in elements)
Location location = element.Location;
if (location != null)
LocationPoint locationPoint = location as LocationPoint;
if (locationPoint != null)
XYZ position = locationPoint.Point;
totalX += position.X;
totalY += position.Y;
totalZ += position.Z;
count++;
// Calculate the average position to get the center point
if (count > 0)
double centerX = totalX / count;
double centerY = totalY / count;
double centerZ = totalZ / count;
return new XYZ(centerX, centerY, centerZ);
return null; // Return null if no valid elements are found
using System;
using System.Linq;
using System.Text;
ref string message,
double totalX = 0;
double totalY = 0;
double totalZ = 0;
int count = 0;
count++;
if (count > 0)
2 REPLIES 2
Mohamed_Arshad
HI @josenlee34_21
    What you have did was not right method every element does not has Location Point I modified your code little bit, Kindly follow the below steps:
  1. Get BoundingBox for each element
  2. Get Min and Max of the bounding box
  3. Calculate most Min and most Max of the BoundingBox Min and Max.
  4. And by using general formula (Min+Max/2) you can get the center point of the complete model.
Reference Code
 public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            FilteredElementCollector collector = new FilteredElementCollector(doc, doc.ActiveView.Id); //Filter in Active View
            XYZ centerPoint = GetCenterPoint(allElements, doc.ActiveView);
            using (Transaction createPoint = new Transaction(doc, "Create Center Point"))
                createPoint.Start();
                //Create Point to Check the whether it is in center or not
                DirectShape point = DirectShape.CreateElement(doc,new ElementId( BuiltInCategory.OST_GenericModel));
                point.AppendShape(new List<GeometryObject>() { Point.Create(centerPoint) });
                createPoint.Commit();
        private XYZ GetCenterPoint(ICollection<Element> elements, View activeView)
            List<double> minX = new List<double>();
            List<double> minY = new List<double>();
            List<double> minZ = new List<double>();
            List<double> maxX = new List<double>();
            List<double> maxY = new List<double>();
            List<double> maxZ = new List<double>();
                BoundingBoxXYZ bb = element.get_BoundingBox(activeView);
                if (bb != null)
                    minX.Add(bb.Min.X);
                    minY.Add(bb.Min.Y);
                    minZ.Add(bb.Min.Z);
                    maxX.Add(bb.Max.X);
                    maxY.Add(bb.Max.Y);
                    maxZ.Add(bb.Max.Z);
            //Get Mininum of the points
            double min_X = minX.Min();
            double min_Y = minY.Min();
            double min_Z = minZ.Min();
            //Get Maximum of the points
            double max_X = maxX.Max();
            double max_Y = maxY.Max();
            double max_Z = maxZ.Max();
            //Create 3D Point
            XYZ min = new XYZ(min_X, min_Y, min_Z);
            XYZ max = new XYZ(max_X, max_Y, max_Z);
            //Create Center Point
            XYZ centerPoint = new XYZ();
            centerPoint = min.Add(max).Divide(2.0);
            return centerPoint; // Return null if no valid elements are found
Hope this will Helps 🙂
Thanks & Regards,
Mohamed Arshad K
HI @josenlee34_21
Reference Code
                if (bb != null)
                    minX.Add(bb.Min.X);
                    minY.Add(bb.Min.Y);
                    minZ.Add(bb.Min.Z);
                    maxX.Add(bb.Max.X);
                    maxY.Add(bb.Max.Y);
                    maxZ.Add(bb.Max.Z);
            //Create 3D Point
Thanks & Regards,
Mohamed Arshad K
josenlee34_21
Thanks so much man.
Thanks so much man.
