Cannot Open .rfa File
Hi all,
I'm having some issues importing *.rfa files into a project via code.  I've created a watered down version of the code I am using below:
string currentDirectory = "C:/Users/spaceroppa/Documents/bim_examples/";
string fileName = "Single Window.rfa";
string fullPath = currentDirectory + fileName;
if (!File.Exists(fullPath))
	TaskDialog.Show("Load Bim Object", "Can't find the file " + fullPath);
Document rvtDoc = uiApp.ActiveUIDocument.Document;
using (Transaction t = new Transaction(rvtDoc, "Import Bim Object"))
	t.Start();
	bool loadSuccess = rvtDoc.LoadFamily(fullPath);
	t.Commit();
	if (loadSuccess)
		TaskDialog.Show("Load Bim Object", fullPath + " successfully loaded!");
	} else
		TaskDialog.Show("Load Bim Object", "Failed to load " + fullPath);
However, I cannot get this to work correctly.  Can anybody point out what I've done wrong or provide me with a functional example?
Cheers,
Adam
matthew_taylor
Try putting backslashes in your path.
If the family is already loaded in the model, that can cause issues also.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Hi Matthew,
Thanks for the speedy response!
It would appear my problem was caused because the family already existed in the test project I was working on, even though I could have sworn I deleted it before I began testing earlier..  I'll add a check to my code to see if the Family already exists before attempting import.
I feel like quite the fool now!  Perhaps it is time to take a break.
Thanks again,
Adam
matthew_taylor
Hi Adam,
No problem.
Yes, do that. Much faster than loading anyway!
Glad you got it sorted.
-Matt
p.s. Don't be so hard on yourself!
Cheers,
-Matt
