07:18 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I'm having some issues importing *.rfa files into a project via code. I've created a watered down version of the code I am using below:
string currentDirectory = "C:/Users/spaceroppa/Documents/bim_examples/"; string fileName = "Single Window.rfa"; string fullPath = currentDirectory + fileName; if (!File.Exists(fullPath)) { TaskDialog.Show("Load Bim Object", "Can't find the file " + fullPath); } Document rvtDoc = uiApp.ActiveUIDocument.Document; using (Transaction t = new Transaction(rvtDoc, "Import Bim Object")) { t.Start(); bool loadSuccess = rvtDoc.LoadFamily(fullPath); t.Commit(); if (loadSuccess) { TaskDialog.Show("Load Bim Object", fullPath + " successfully loaded!"); } else { TaskDialog.Show("Load Bim Object", "Failed to load " + fullPath); } }
However, I cannot get this to work correctly. Can anybody point out what I've done wrong or provide me with a functional example?
Cheers,
Adam
