Cannot get Project Base Point parameters from linked model
ediloreto8W6MG
ediloreto8W6MG
I'm trying to get the "N/S", "E/W", "Elev" and "Angle to True North" parameters from a PBP in a linked model. I'm using RevitPythonShell. The problem is I can only access to this parameters:
- Edited by
- Type Name
- Family Name
- Workset
- Category
- Design Option
What could be the reason?
app = doc.Application
docs = app.Documents
for d in docs:
    if d.Title != doc.Title:
        l_doc = d
        break
collector = FilteredElementCollector(l_doc);
points = collector.OfClass(BasePoint)
for p in points:
    if not p.IsShared:
        pbp = p
        break
for p in pbp.Parameters:
    print(p.Definition.Name)
jeremy_tammik
Here is a thread demonstrating a completely different approach:
https://forums.autodesk.com/t5/revit-api-forum/how-to-get-true-north-direction-in-xyz/m-p/11018348
Does that help? Let us know. Thx!
ediloreto8W6MG
It worked! Thanks for your time!
