can we use C# to write a code in Revit API that can read alignments based on corresponding profiles?
gkhalifah
gkhalifah
Hello everybody
i have an idea but i don't know if is it possible or not , can we use C# to write a code in Revit API that can read alignments based on corresponding profiles and plot them in Revit to use them later to make a model if that is possible is it possible as raw material or i can make window that displays the profile and alignment in the plugin itself as an interactive view to show the user the alignments as in Cvil 3D ,,, please if someone has the answer i will be happy to know it
[The subject line of this post has been edited for clarity by Community Manager. Original: Revit API]
naveen.kumar.t
Autodesk Support
Autodesk Support
We have
Civil Alignments API in Revit. Looks like, this API supports read of alignment properties and geometric information.
Could you please take a look at the below links and let me know?
https://help.autodesk.com/view/RVT/2025/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Discipline_Sp...
https://forums.autodesk.com/t5/civil-3d-forum/workflow-for-importing-amp-updating-tunnel-alignment-f...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
