can we able to autogenerate ifcguid using revit api for 2021
gowtham_venkitusamy
gowtham_venkitusamy
In 2021 version 2021 there is no ifcguid ,if any possible to autogenertae ifcguid using revit api for 2021 version ,i tried this code for 2021 version but it does not generate ifcguid
Autodesk.Revit.DB.IFCExportOptions options = new Autodesk.Revit.DB.IFCExportOptions();
options.AddOption("StoreIFCGUID", true.ToString());@autodesk
jeremy_tammik
I very much doubt it. To make sure, you might want to check with the IFC experts in the IFC discussion group:
