Can´t load RevitLookup 2015
Hi
I have a problem loading RevitLookup 2015
I got  the error:
System.IO.FileLoadExecption
Could not load file or assembly
......\RevitLookup.dll or one of its dependencies. Operation is not supported. (Exeption from HRESULT: 0x80131515)
Hope anyone can help me 🙂
Anders
Charles.Piro
the assembly is in your computer or in a server ?
PIRO Charles
Developer
PIRO CIE
Linkedin
Hi
The Addin and DLL files are both located at C:\ProgramData\Autodesk\Revit\Addins\2015
Anders
rosalesduquej
Hi Anders,
Is the path inside of your Addin file pointing out to the right location ? could you double check.
If it is I think you will be better off removing it completly and getting it again from a fresh start.
Is any other plugin in the folder location working ? Was your RevitLookup working before ?
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Hi
Yes I think so
The addin file lokk like this:
<?xml version="1.0" encoding="utf-8" standalone="no"?>
<RevitAddIns>
   <AddIn Type="Application">
      <Assembly>C:\ProgramData\Autodesk\Revit\Plugins\2015\RevitLookup.dll</Assembly>
      <ClientId>356CDA5A-E6C5-4c2f-A9EF-B3222116B8C8</ClientId>
      <FullClassName>RevitLookup.App</FullClassName>
      <Name>Revit Lookup</Name>
      <VendorId>ADSK</VendorId>
      <VendorDescription>Autodesk, www.autodesk.com</VendorDescription>
   </AddIn>
</RevitAddIns>
And the RevitLookup.dll is placed in the folder:
And I have others addin working from that folder.
I have tried to delete and download new files
I just changed computer that why I had to reinstall Revit Lookup again 🙂
Anders
rosalesduquej
Mm very strange, did you have the latest version of it ? https://github.com/jeremytammik/RevitLookup/releases 2015.0.0.8 ?
Also The way I have setup mine is to load the DLL from a different location, I only keep my addin files in that folder, the Dll depending on the development I'm doing they stay in there debug folder in case I do any changes and the addin keeps reading the most up to date version of it.
Could you try moving your dll to a different path and update your addin file with the new location. Also try to rebuild a new version of the VS solution.
Silly thing to suggest but It is kinda strange to me that you cannot load it.
Cheers,
Jaime Rosales D.
agenna
Depending on the version of windows you have, you may need to right-click > properties... and UNBLOCK the .dll
all the while thanking Microsoft for enhancing my security.
