Can not add connetions between walls and floors using Dynamic update
awesomeoneee
awesomeoneee
hi,All
I'm trying to make an add-in which is used to correct(or adjust) the connection between components such as walls, columns, beams and floors after placing. There exists an error while the Dynamic update codes work on a wall trying to make a connection with another floor, and there is no detail message about the error. Any ideas to solve this?
Screenshot:
Key codes below:
public void Execute(UpdaterData data)
            Document document = data.GetDocument();
            List<ElementId> additionElementIds = data.GetAddedElementIds().ToList();
            //List<ElementId> modifiedElementIds = data.GetModifiedElementIds().ToList();
            View view = document.ActiveView;
            foreach (ElementId elementId in additionElementIds)
                Element element = document.GetElement(elementId);
                if (element != null)
                    List<Element> intersectedElements = new FilteredElementCollector(document,view.Id).
                            WherePasses(GetBoundingBoxIntersectsFilter(element, view)).Where(x => x.Id != elementId).ToList();
                    if (intersectedElements.Count > 0)
                        foreach (Element intersectedElement in intersectedElements)
                            try
                                JoinGeometryUtils.JoinGeometry(document, element, intersectedElement);
                            catch (Exception ex)
                                TaskDialog.Show("Error", ex.Message.ToString() + "\n" + intersectedElement.GetType().ToString());
                                continue;
private BoundingBoxIntersectsFilter GetBoundingBoxIntersectsFilter(Element element,View view)
            XYZ boundingBox_min = element.get_BoundingBox(view).Min;
            XYZ boundingBox_max = element.get_BoundingBox(view).Max;
            Outline outline = new Outline(boundingBox_min, boundingBox_max);
            return new BoundingBoxIntersectsFilter(outline);
jeremy_tammik
Maybe your updater is making a change to the model that results in the same updater being triggered again. That would generate an infinite loop if it was not detected and terminated by Revit.
RPTHOMAS108
I don't think bounding box intersecting is a good enough indication of if two elements can be joined. There will be an exception if the elements can't be joined. When your geometry is view specific it may not have the full 3D extents you would otherwise expect.
Additionally you should probably not show a task dialog in your execute method since Execute may be called multiple times for the same transaction due to changes from other updaters. There is a lot of automatic joining that goes on so there is probably a conflict with that process. Elements of same concrete material are joined automatically.
