Can I use 2014 API while I am using revit 2012 version?
natanatalili
natanatalili
Can I use 2014 API while I am using revit 2012 version? How can I do that?  thanks.
ollikat
Hi
You mean are you able to run such a add-in that is built agains 2014 API under Revit 2012?
In general I don't think it will work, even if you would use only methods/properties that are supported by 2012. I'm afraid that API between versions aren't binary compatible.
Someone from ADSK can confirm this but I think your odds are quite small.
Joe.Ye
You cannot use the API that is exposed for Revit 2014 on Revit 2012. There will be compilation error.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
