- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Can I use 2014 API while I am using revit 2012 version? How can I do that? thanks.
Hi
You mean are you able to run such a add-in that is built agains 2014 API under Revit 2012?
In general I don't think it will work, even if you would use only methods/properties that are supported by 2012. I'm afraid that API between versions aren't binary compatible.
Someone from ADSK can confirm this but I think your odds are quite small.
