Can I Separate a curved wall by the number of layers?
dh_kim
dh_kim
This photo is the Origin Wall.
I want to separate this wall by number of layers.
Number of layers in this wall = 6
Can you isolate this wall and create a new wall layer?
When you create as many walls as the number of layers, you want the location of the walls to be the same as the existing walls.
jeremy_tammik
Yes, sure. You can split the wall into parts. I believe that each item in the walls compound layer structure generates a separate part. Another option is to analyse the wall compound structure layers and generate a new wall element for each layer. I suggest that you determine the best practices for your task manually in the end user interface before addressing the programming task. Here are several examples of analysing and processing the wall's compound layer structure:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.17
