Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Can I Filter different BuiltInCategories at same time
6 REPLIES 6
hctungBHP7B
288 Views, 6 Replies
Hi, I am wondering that is it possible to filter different BuiltInCategories at same time?
Because I want to improve my code efficiency in my big Revit file, so I only want to filter once
Or Any other ways can get  instances of those BuildInCategories  in a list??
bic_beam = DB.BuiltInCategory.OST_StructuralFraming
bic_collumn = DB.BuiltInCategory.OST_StructuralColumns
bic_beam_tag = DB.BuiltInCategory.OST_StructuralFramingTags
bic_collumn_tag = DB.BuiltInCategory.OST_StructuralColumnTags
 So far, I only know basic collector and filter to achieve one BuiltInCategory.
collector = DB.FilteredElementCollector(doc, doc.Active.Id)
beam_filter = DB.ElementCategoryFilter(DB.BuiltInCategory.OST_StructuralFraming)
beam_elements = collector.WherePasses(beam_filter ).ToElementIds()
 Thanks for your time, Any helpful advise is very appreciated.
6 REPLIES 6
jeremy_tammik
in reply to: hctungBHP7B
First, a comment on your second code snippet: it is always advisable to use the filter shortcuts. In this case, use OfCategory instead of ElementCategoryFilter + WherePasses. It is shorter, clearer, and guarantees that you are using a quick collector.
Second, the answer to your question is yes. I think this is the one and only purpose of the FilterCategoryRule class:
https://www.revitapidocs.com/2022/7df5b10b-c423-b5c8-6492-1274d7a447d9.htm
Read the article on how to use FilterCategoryRule for more info:
https://thebuildingcoder.typepad.com/blog/2018/05/how-to-use-filtercategoryrule.html
It also mentions how you can easily achieve the same without using FilterCategoryRule:
For yet more info, please refer to The Building Coder topic group on filtering for elements:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.9
Jeremy Tammik, Developer Advocacy and Support, The Building Coder, Autodesk Developer Network, ADN Open
Yien_Chao
you can also use multicategoryfilter : https://www.revitapidocs.com/2022/e43a304a-6931-7492-441c-3cac428f2431.htm
so instead of using categories Id, you will need a list of builtinCategory names
ex:
cat_list = [BuiltInCategory.OST_Walls, BuiltInCategory.OST_Windows, BuiltInCategory.OST_Doors,BuiltInCategory.OST_Floors,BuiltInCategory.OST_Ceilings]
types= List[BuiltInCategory](cat_list)
multiCat = ElementMulticategoryFilter(types)
Elements = FilteredElementCollector(doc).WherePasses(multiCat).WhereElementIsNotElementType().ToElements()
hctungBHP7B
in reply to: Yien_Chao
@Yien_Chao Thank you ! That is exactly what I need!
hctungBHP7B
in reply to: jeremy_tammik
@jeremy_tammik  Thanks for your detailed replies, I am really appreciated!
For my understanding, OfCategory  and  ElementCategoryFilter + WherePasses, That two method can achieve same goal. In addition, Those two ways are both quick filter. However, using OfCategory directly can be more readable and clearer.
Am I right?  Please correct me if I am wrong. Thanks
FilterCategoryRule, Thank you this suggestion ,I will check which one is better comparing to ElemenetMulticategoryFilter.
jeremy_tammik
No, that is absolutely correct.
> which one is better...
I prefer ElementMulticategoryFilter myself, now I think about it. It is clearer and more direct.
jeremy_tammik
Thank you for raising this once again. I summarised our conversation on the blog:
https://thebuildingcoder.typepad.com/blog/2022/06/outer-walls-lookup-update-and-filtering.html#3
Rail Community
