call the size of elements using python
husam_al-jawhar
husam_al-jawhar
I'm currently working on a project in Revit and I need to call the size of slabs, columns, and beams and print theses sizes by using python 2. Could you please advise me on how to do this? I've been trying to figure it out on my own, but I haven't had any luck.
Thank you for your time and help
jeremy_tammik
For a rough first estimate that works for almost all elements, you can simply call the BoundingBox property and determine its X, Y and Z length:
https://www.revitapidocs.com/2023/def2f9f2-b23a-bcea-43a3-e6de41b014c8.htm
The bounding box is axis aligned. Hence, the results will mostly be pretty accurate for axis aligned objects. For non-aligned elements, the values will be too large.
husam_al-jawhar
Hi Jeremy, Many thanks for your answer, it works for columns and slabs, but for the beams, it is not work, and I am using precast L shape beams in this project; any advice for that?
Cheers,
jeremy_tammik
Simply use the beam location line length for the long dimension, and the beam width and height for the cross section dimensions.
husam_al-jawhar
Hi Jeremy,
I wanted to say thank you for your insightful answer about the problem. Your explanation was helpful and gave me a better understanding of the topic. Your willingness to share your knowledge is greatly appreciated!
Best,
Husam
