Call an ExternalEvent from another assembly.
Thomas_LECUPPRE_Let_it_BIM
Message 1 of 14
Hi, this is probably a newbie question but I can't found an answer on internet.
I'm creating a plugin that interact with a database and I'm trying to separate all my UI code to "Revit Code". In this way, I don't need reference to RevitAPI and Revit APIUI dll's in UI part. But here is my problem, how to call my revit event from this UI code ? If I load my UI code assembly in "Revit Code" there is no problem but if I need "Revit Code" in UI Code, I will create a loop.
I know how to do it for a simple WPF project but with event like this, I don't know.
Can someone help me with some explanation or example ?
Replies (13)
Message 2 of 14
ricaun
You probably gonna need to create some custom interface on the UI assembly, to inject on the 'Revit Code'.
Some ICommand should be useful too.
// Source: https://stackoverflow.com/questions/57379255/close-window-wpf-in-revit
public class RelayCommand : ICommand
    private Action<object> execute;
    private Func<object, bool> canExecute;
    public event EventHandler CanExecuteChanged
        add { CommandManager.RequerySuggested += value; }
        remove { CommandManager.RequerySuggested -= value; }
    public RelayCommand(Action<object> execute, Func<object, bool> canExecute = null)
        this.execute = execute;
        this.canExecute = canExecute;
    public bool CanExecute(object parameter)
        return this.canExecute == null || this.canExecute(parameter);
    public void Execute(object parameter)
        this.execute(parameter);
See yaa.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Message 3 of 14
Thank you for your answer. Of course I will need this but it is the point where my current knowledge stop. I'm asking for help because I don't know how to do that. If you can provide me some example, sources, or article, I will be happy.
For this ICommand part, I already use this in my code, because of MVVM pattern.
EDIT :
Other thing, I try to not use Revit API and APIUI  as dependcies in 'UI Code'. Because these Dll depend of the Revit verison (wich depend of the revit version install on final user computer).
Message 4 of 14
Kennan.Chen
You need to define interfaces to use dependency inversion or IoC to create a loosely-coupled architecture.
For example, if you want to show all the family names in your ui, you may do it like this:
// plugin
public class Command : IExternalCommand
    public Result Execute(ExternalCommandData commandData)
        var window = new MyWindow(new FamilyService(commandData.Application));
        window.ShowDialog();
        return Result.Succeeded;
public class FamilyService : IFamilyService
    private UIApplication _app;
    public FamilyService(UIApplication app)
        this._app = app;
    public string[] GetFamilyNames()
        return new FilteredElementCollector(this._app.ActiveUIDocument.Document).OfType(typeof(Family)).Cast<Family>().Select(family => family.Name).ToArray();
// ui lib (not depending on plugin and revit api)
public interface IFamilyService
    string[] GetFamilyNames();
public class MyWindow : Window
    private string[] FamilyNames;
    public MyWindow(IFamilyService familyService)
        this.FamilyNames = familyService.GetFamilyNames();
        // initialize ui
Actually, Revit itself leverages the same design pattern, the IExternalCommand, IExternalApplication, IExternalEventHandler etc are all provided for dependency inversion.
Hope it helps!
Message 5 of 14
Hi, I see what you mean but it's not really what I'm look for. To be more explicit, I don't want to see Autodesk Revit dll as references in my UI project. I want to call the UI from an external dll and come back to revit "brain" to execute my external event.
Would I be able to to this if I use your package in VS @Kennan.Chen. I saw this on an old post in this forum and visit your github 🙂
Message 6 of 14
Kennan.Chen
Hi, I don't see any mismatch between what I said and what you want. Maybe I just failed to express my ideas correctly as a none-native English speaker.
Basically, you want to decouple your UI library with Revit so that you can initialize the same UI across different products.
I actually did the same work in a component library project. The project outputs a Revit addin, a standalone desktop application and a plugin for a self-owned design product like Revit. They all share the same UI.
To make it work, any reference to a specific platform is not allowed in the UI library.
A simple solution is to design multiple interfaces(IFamilyService .etc) and data types(IFamilyData .etc) to abstract the business logic right inside the UI library and then implement those interfaces in the three products with platform specific data and APIs.
In a word, if A cannot be directly used by B, abstract it  in B and create a shell for A to match the abstraction and inject the shell to B.
Message 7 of 14
I think I don't have the knowledge to this for now but I will try. I know where I want to go but don't know how for now. Do you have an link to read more about this ?
EDIT : Can you share with me the tree structure of your Revit addin, standalone desk app ans plugin ? I'm trying you solution but don't know how to organize it correctly.
Message 8 of 14
Kennan.Chen
Hi, I created a demo project to show the ideas. See the attachment of this comment.
The demo shows only the basic ideas of IoC. For more complicated business, the container technology should be involved to better manage dependencies.
Note that I didn't have a Revit environment to run a single test and it's been a long time since my last Revit programming, which means the code may have a big chance to fail at runtime.
Just read the code and try to fix any runtime error yourself.
Hope it helps!
Edit: I update the demo to include a WPF standalone application to complete the solution.
Another word, comparing this solution with a standard or a protocol in real world(like different kinds of physical ports on electronic devices), the interface defined in the UI lib is a kind of protocol that the UI requires for communicating with outside world without knowing any detail of that world.
Message 9 of 14
What the application should show when opened ? The window appears but nothing in it. In what context in Revit (like open it in project, family. With or without family load in it ?) should I start it ?
Message 10 of 14
Kennan.Chen
The window shows a list of families in the currently open project
Message 11 of 14
Hi, I have worked as you show me but I got a last problem, Revit seems not allow me to start my plugin because it can't access dependency.
To be able to update my programme without restarting revit I use this :
        public Result Execute(ExternalCommandData commandData, ref string message, Autodesk.Revit.DB.ElementSet elements)
            try
                string assemblyPath = @"C:\ProgramData\Letitbim\ProfilMaker.dll";
                string assemblyType = "ProfilMaker.Command";
                string methodName = "Execute";
                byte[] assemblyBytes = File.ReadAllBytes(assemblyPath);
                Assembly dataAssembly = Assembly.Load(assemblyBytes);
                Type type = dataAssembly.GetType(assemblyType);
                var instance = Activator.CreateInstance(type);
                var method = type.GetMethod(methodName);
                method.Invoke(instance, new object[] { commandData, message, elements });
            catch (Exception ex)
                MessageBox.Show($"{ex.Message}\n\n{ex.InnerException}\n\n{ex.Source}\n\n{ex.StackTrace}");
from the same dll that generate my button in Revit application. (look like : app.cs (code that create button etc), every button point to mybutton.cs and execute code above. app.cs and every mybutton.cs are build in the same .dll file)
I already explain my problem here. Consider that A is Revit plugin part (command.cs) and B is my ui.
Thank for futur help.
Message 12 of 14
Kennan.Chen
You can subscribe to the AppDomain.AssemblyResolved event to manually resolve the missing assembly when the AppDomain fails to resolve some assembly automatically.
Message 13 of 14
Is that because my dependencies (ui DLL files) isn't load in "app" dll that I can't success that ?
I read AppDomain.AssemblyResolve Microsoft docs, but without clearly understand what it does, it is difficult to apply this to my code 🙂
Message 14 of 14
Ok I got it.
First I subscribe to AppDomain.AssemblyResolve event like this :
AppDomain.CurrentDomain.AssemblyResolve += ResolveAssembly;
private Assembly ResolveAssembly(object sender, ResolveEventArgs args)
      string name = args.Name.Split(',')[0];
      return Assembly.LoadFile(@"C:\YourPath\" + name + ".dll");
Because my system is french culture, I had some trouble with this. So by checking the culture of the the assembly before sending it, I return null if assembly isn't neutral culture and that work !
Final method :
      string culture = args.Name.Split(',')[2];
      // Si la culture n'est pas neutre alors on passe.
      if (name.EndsWith(".resources") && !culture.EndsWith("neutral")) return null;
