3D View Manipulation
jshial
jshial
Hi community,
I am trying to simulate View Cube by assigning a transformed BoundingBoxXYZ to View3D.CropBox property. As far as I have observed, changes happen to CropBox property when I use View Cube to manipulate 3D view.
Seemingly, it does not work.
Assume I have already oriented the 3d view to look downward, now I want to rotate the view itself for 90 degree. The process I have in mind is:
Yet, nothing happens.
Any help will be appreciated. Happy Little-Bit-Late New Year!
jeremy_tammik
In your code, you are setting the crop box.
I do not believe that that affects the view.
I think you need to set up the camera, view direction, etc.
This example ought to show you how this can be achieved:
https://thebuildingcoder.typepad.com/blog/2019/06/revit-camera-settings-project-plasma-da4r-and-ai.h...
jshial
Hi Jeremy,
I made it thanks for your help. But still have some confusion.
At very beginning, I had the same idea of setting the camera orientation. So I had set the camera to look downward. The reason I did not keep explore camera settings and went for CropBox (except for the change on CropBox's transform), was a little test I made:
I took out my phone,  aim at my screen. Gradually, tilt my phone camera from 0 ~ 90 degree. So location and gaze direction remains the same, only up direction changes. I realize the image/scene changes from Portrait to Landscape, yet the image/scene itself is static.
But same process for virtual camera in a View3D instance indeed "rotate" the scene. I am still a bit confused over the difference here. Could you elaborate more on this?
jeremy_tammik
Glad to hear you made it! Thank you for your appreciation.
I think the rotation that you mean is defined by the ViewOrientation3D UpDirection property:
https://www.revitapidocs.com/2022/1353f55a-719d-75d2-a095-a70fbde71a4c.htm
jshial
indeed. I had never taken Up Direction seriously. Thx Jeremy!
