Calculating Window Areas using RevitPythonShell
Hi Everyone,
I have run into something I thought was quite interesting, but I also have no idea what to make of it.
If I calculate the area of a window in Revit, using a simple formula to multiply the Width by the Height in a schedule, it works fine;
However, If I try and get the area of the same window using the RevitPythonShell, I get a completely different result;
(The multiplication is just to convert ft² to M²)
Can anyone explain this to me? I am very new to programming in general, so am I writing the code incorrectly?
If it is correct, where is Revit retrieving the "Area" Value from? As a window in Revit does not have area as a standard parameter.
I would really appreciate any feedback.
Thanks so much
Mitch.
aignatovich
Hi!
Try this:
import clr
clr.AddReference ("RevitAPIIFC")
from Autodesk.Revit.DB.IFC import *
from System.Collections.Generic import *
wall = doc.GetElement(ElementId(199301))
window = doc.GetElement(ElementId(207029))
windowCurveLoop = ExporterIFCUtils.GetInstanceCutoutFromWall(doc, wall, window)[0]
loops = List[CurveLoop]()
loops.Add(windowCurveLoop)
print UnitUtils.ConvertFromInternalUnits(ExporterIFCUtils.ComputeAreaOfCurveLoops(loops), DisplayUnitType.DUT_SQUARE_METERS)
Thanks very much for the response, it did work.
Do you have any idea why my method does not work? In this case, I am more interested in understanding what the problem is than I am in getting the result.
Thanks again!
aignatovich
I think there are two reasons for it:
1) potential user family complexity
2) legacy families
If you create standard window family instance M_Fixed (shipped with Revit) of 0406 x 0610 mm family type, you'll see that its area is one square meter. Why? I don't know...
Very strange..
Anyway, thank you for your input, really appreciated!
