Built-in parameter definitions
ollikat
ollikat
Hi all!
Does anyone know, is it possible to retreive built-in parameter definitions (InternalDefinition) without having actual Parameter object(s)?
Document::ParameterBindings() returns only shared parameters etc. but no built-in parameters.
adam.nagy
Autodesk Support
Autodesk Support
Hi there,
Do you want to get the buil-in parameter definition to retrieve its name?
Then this should help:
http://thebuildingcoder.typepad.com/blog/2011/08/built-in-parameter-name-and-labelutils.html
Cheers,
Adam Nagy
Autodesk Developer Network
Adam Nagy
Autodesk Platform Services
ollikat
Yes...I think that satisfies my needs also.
Thanks!
