Bug Report, Revit API 2016: Deleted View problem
StruSoft_Iwona
StruSoft_Iwona
I created an addin command what creates a view. If I delete that view in Revit and use the addin command again I get an exception. But not always. If I change between views a few time before the command, sometimes I dont get exception. I think the document.ActiveView gives back the deleted view or something like that.
StruSoft_Iwona
As I thought ... active view name: "???"
In revit dialog the active view is automatically selected after a view deletion but the API dont give that view back as active view.
After creation:
After deletion (3D view automatically selected and the exception occurs):
Revitalizer
it would be better to use uiApp.ActiveUIDocument.ActiveGraphicalView insted of a document's ActiveView since there may be active (focused) non-graphical views, e.g. Project browser, properties palette or custom palettes.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
JimJia
Thanks Revitalizer, I also think UIDocument.ActiveGraphicalView is safer choice.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
