- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm working with the Revit 2015-2018 APIs, and this problem manifests itself with all versions.
Within my plugin, I'm getting a Material, AppearanceAsset and then the Asset itself to determine the appearance properties thus :-
Material material = document.GetElement(materialid) as Material;
AppearanceAssetElement appearance = document.GetElement(material.AppearanceAssetId) as AppearanceAssetElement;
Asset asset = appearanceElem.GetRenderingAsset();
However, for some Materials, the AppearanceAssetId is set to {-1}, so effectively there is no AppearanceAssetElement or Asset to fetch, as per the MaterialDebug.png
But, when I open the Materials Panel in Revit, the Material clearly has an Appearance Asset & Assets defined, as per the MaterialPanel.png.
Is this a bug in the API, or is there some other mechanism by which a Material and Appearance Asset are linked together?
This makes absolutely no sense to me. It only manifests itself for certain materials, but behaves consistently across multiple trials.
