BoundingBox Corner Coordinates
floretti
Message 1 of 14
floretti
Hi all, I've got a challenge I haven't quite worked out how to tackle yet and some help would go a long way before I invest days into it.
I need to collect my FamilyInstances' BoundingBox, "move" their boundaries inwards by specific amounts (arrows 1 to 4 below) and collect the resulting corners (A, B, C and D below). Any suggestions on how to achieve that or places I can find small snippets of code which could potentially help? Much appreciated.
I'm very familiar with collecting the BoundingBox of elements but I realise I may need to get into some more advanced maths topics such as normals and vectors, which I'm not as familiar especially in the coding world.
Replies (13)
Message 2 of 14
floretti
Just reporting on progress, the good news is that I managed to find a way to get the new coordinates of points based on the distance and angle.
The bad news is that I just realised that the BoundingBox for something that's been rotated is like the red lines below, which shows that my original plan won't work. Back to the drawing board...
Message 3 of 14
floretti
Ok, just reporting on progress, I managed to make the BoundingBox work by collecting the Symbol BoundingBox's 4 corners and applying the instance's point transform to each. The result is an accurate angled box, which I can then apply the formula shown above to each corner based on the instance's location angle and the desired distances (1, 2, 3 and 4). I'll keep going tomorrow and post the result here.
Message 4 of 14
floretti
Ok, I resolved my own problem but I'll post the code here in case anyone comes across this in the future.
foreach (FamilyInstance instance in famInstances)
	if (instance.ViewSpecific != true)
		Location instLocation = instance.Location;
		LocationPoint instLocPt = instLocation as LocationPoint;
		Double instRotationRad = instLocPt.Rotation;
		double instRotationDeg = UnitUtils.ConvertFromInternalUnits(instRotationRad, DisplayUnitType.DUT_DECIMAL_DEGREES);
		// Collect 4x corners of symbol Bbox
		BoundingBoxXYZ symBox = instance.Symbol.get_BoundingBox(doc.ActiveView);
		XYZ symBoxBL = symBox.Min;  // BL=bottom left
		XYZ symBoxTR = symBox.Max;  // TR=top right
		XYZ symBoxTL = new XYZ(symBoxBL.X, symBoxTR.Y, 0);
		XYZ symBoxBR = new XYZ(symBoxTR.X, symBoxBL.Y, 0);
		// Apply transform to each corner to find actual instance Bbox coordinates
		var transf = instance.GetTransform();
		XYZ coordBL = transf.OfPoint(symBoxBL);
		XYZ coordTR = transf.OfPoint(symBoxTR);
		XYZ coordTL = transf.OfPoint(symBoxTL);
		XYZ coordBR = transf.OfPoint(symBoxBR);
		// L=left, B=bottom, R=right, T=top
		double distL = 30;
		double distB = 15;
		double distR = 20;
		double distT = 10;
		//Formulas
		//double newX = oldX + dist * Math.Cos(angle * Math.PI / 180);
		//double newY = oldY + dist * Math.Sin(angle * Math.PI / 180);
		#region BOTTOM LEFT CORNER
		double startBLx = coordBL.X +
					   UnitUtils.ConvertToInternalUnits(distL, DisplayUnitType.DUT_MILLIMETERS) *
					   Math.Cos((instRotationDeg) * Math.PI / 180);
		double startBLy = coordBL.Y +
					   Math.Sin((instRotationDeg) * Math.PI / 180);
		double finalBLx = startBLx +
				   UnitUtils.ConvertToInternalUnits(distB, DisplayUnitType.DUT_MILLIMETERS) *
				   Math.Cos((instRotationDeg + 90) * Math.PI / 180);
		double finalBLy = startBLy +
					   Math.Sin((instRotationDeg + 90) * Math.PI / 180);
		Log.Information("BotL: ({0},{1})", finalBLx, finalBLy);
		#endregion
		#region BOTTOM RIGHT CORNER
		double startBRx = coordBR.X +
					   UnitUtils.ConvertToInternalUnits(distR, DisplayUnitType.DUT_MILLIMETERS) *
					   Math.Cos((instRotationDeg + 180) * Math.PI / 180);
		double startBRy = coordBR.Y +
					   Math.Sin((instRotationDeg + 180) * Math.PI / 180);
		double finalBRx = startBRx +
		double finalBRy = startBRy +
		Log.Information("BotR: ({0},{1})", finalBRx, finalBRy);
		#endregion
		#region TOP RIGHT CORNER
		double startTRx = coordTR.X +
		double startTRy = coordTR.Y +
		double finalTRx = startTRx +
				   UnitUtils.ConvertToInternalUnits(distT, DisplayUnitType.DUT_MILLIMETERS) *
				   Math.Cos((instRotationDeg + 270) * Math.PI / 180);
		double finalTRy = startTRy +
					   Math.Sin((instRotationDeg + 270) * Math.PI / 180);
		Log.Information("TopR: ({0},{1})", finalTRx, finalTRy);
		#endregion
		#region TOP LEFT CORNER
		double startTLx = coordTL.X +
		double startTLy = coordTL.Y +
		double finalTLx = startTLx +
		double finalTLy = startTLy +
		Log.Information("TopL: ({0},{1})", finalTLx, finalTLy);
		#endregion
Message 5 of 14
joseph.he
I know its been a while since you posted this, but just wanted to say massive thanks for going through and posting the code and solution. Thank you!
Message 6 of 14
floretti
I get a lot of help from people in this forum. It would only be fair to give some back. 🙂
Message 7 of 14
mizrachi_amir2
Thanks, @floretti, for sharing this!
I am assuming that your solution is based on instances that are Point based (their Location is LocationPoint) and not a Curve based.
As far as I understand from a short research on that - instances that have LocationCurve do not need to have this kind pf transformation in their bounding box, as their bounding box is at the exact rotation as well.
Am I correct?
Message 8 of 14
jeremy_tammik
The bounding box of an element is always aligned with thr cardinal axes, and never rotated away from those. This means that for a thin, long, angles object, e.g., a 10 cm diameter pipe from 0,0,0 to  10m,10m,10m, the bounding box wil be more or less from 0,0,0 to  10m,10m,10m. So, it will have a volume of 10x10x10 = 1000 cubic metres instead of the optimised non-axis-aligned box that would have only 0.1 x 0.1 x length_of_pipe, which would be about  0.173 cubic metres.
Message 9 of 14
mizrachi_amir2
Then I am confused with the red dashed lines illustrated above.
Why in this case the BB is rotated from the element itself?
Message 10 of 14
floretti
@mizrachi_amir2 I believe the element BB never rotates and it stays aligned to the XYZ axis, even if the element is rotated, hence the red dashed lines. What I had to do to get the rotated BB is, get the Symbol's BB and apply the transform, which has the rotation information.
Message 11 of 14
jeremy_tammik
The bounding box is NOT rotated. It is aligned with the cardinal axes. The element has a rotation.
Message 12 of 14
Chuong.Ho
- In case you don't need care so much about angle and just want to see list point conors follow  the cardinal axes
public static List<XYZ> Corners(BoundingBoxXYZ boundingBox)
    if (boundingBox == null)
        throw new ArgumentNullException("BoundingBox is null");
    XYZ minPoint = boundingBox.Min;
    XYZ maxPoint = boundingBox.Max;
    List<XYZ> corners = new List<XYZ>();
    corners.Add(minPoint);
    corners.Add(new XYZ(minPoint.X, minPoint.Y, maxPoint.Z));
    corners.Add(new XYZ(minPoint.X, maxPoint.Y, minPoint.Z));
    corners.Add(new XYZ(minPoint.X, maxPoint.Y, maxPoint.Z));
    corners.Add(new XYZ(maxPoint.X, minPoint.Y, minPoint.Z));
    corners.Add(new XYZ(maxPoint.X, minPoint.Y, maxPoint.Z));
    corners.Add(new XYZ(maxPoint.X, maxPoint.Y, minPoint.Z));
    corners.Add(maxPoint);
    return corners;
Chuong Ho
Message 13 of 14
mizrachi_amir2
Hi @Chuong.Ho, I do care about the rotation and angles. Meaning if my Element is rotated I need all 6 planes of its (rotated) bounding box.
I just don't get the idea presented here using the GetTransform() - I inspeted a horizontal element and inspected that same element rotated 45 degrees and the returned back value of the Transform attribute was exactly the same in both cases.
Message 14 of 14
floretti
@mizrachi_amir2 Do you mind sharing how you got the Transform for the two elements?
