BooleanOperationsUtils.ExecuteBooleanOperation InvalidOperationException Casue
kimhjDGFZX
kimhjDGFZX
Hi All,
BooleanOperationsUtils.ExecuteBooleanOperation(), When I use this method, I often get an InvalidOperationException.
I would like to know if there are specific criteria for causing that error.
For example, it occurs when elements intersect at an angle below a certain angle, etc.
I hope there are rules for this or some documentation I can refer to.
thanks for reading!
jeremy_tammik
Sorry about that. It has been mentioned before that ExecuteBooleanOperation can run into issues. Unfortunately, afaik, there is no list of the exact criteria which might cause a problem. Various ways of handling the situation and some possible workarounds have been discussed here in the past. You can search for ExecuteBooleanOperation or just Boolean to find some of them:
The development team are aware of these issues. This is one of the more exhaustive discussions on the topic, ongoing ever since 2017, including a suggestion for a non-trivial workaround:
If you would like to provide a complete minimal reproducible case, I can share that with the development team for further analysis:
