Big gap in the view when scale "1:1"
jejeno2544
jejeno2544
Hi all,
I create a top view for the assembly (which consists of 1 pipe) and set the scale to "1:1".
ViewSection viewSection = AssemblyViewUtils.CreateDetailSection(document, assemblyInstanceId, AssemblyDetailViewOrientation.ElevationTop);
viewSection.Scale = "1:1";
After creating, I get a big gap between the element and the detail line in the top view:
Zoomed detail line:
Is there any way to bridge this gap?
jeremy_tammik
You share two lines of programming code, so I assume you are asking this from a Revit API programmer's point of views. However, the Revit API just wraps the standard product end user inerface functionality. So, to address this question, we need to determine how it can be solved in the UI. Do you have any idea? I do not. If not, I would suggest asking in the more UI-savvy Revit Architecture forum. Maybe somebody there knows better. Just looking at your two lines of code, I would assume that this is standard behaviour.
