Better forum?
Better forum?
Better forum?
can anyone direct me to a more active fourm where people are activily working with the Revit API using C#? Thanks.
scott_d_davis
Not a forum, but a blog with great info:
http://thebuildingcoder.typepad.com/blog/
Scott D Davis
Sr AEC Technical Specialist
CADdaddy.com
I have to agree with you.  The user base of this forum has not reached critical mass to the point where you can reliably get an answer to a question.  The AUGI Revit API forum is about the same.  You should probably get an ADN membership if you are in a position where you need reliable API support.  I still use this forum first because I want it to grow into something useful--but if I don't get an answer in a reasonable amount of time-- I go to ADN.
James LeVieux
www.caddaddy.com
