Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Best practices for local data storage
3 REPLIES 3
CollinJoseph0258
1010 Views, 3 Replies
What are the best practices for storing data locally for Revit addins? (for example: user preferences or authentication information)
In particular, is there any recommended location or format?
Labels (2)
3 REPLIES 3
It depends completely on your requirements and personal preferences.
Personally, I favour text over binary, and JSON over XML.
Here are two explorations comparing storage of a very small amount of add-in settings data in JSON and XML respectively:
https://thebuildingcoder.typepad.com/blog/2016/09/hololens-escape-path-waypoint-json-exporter.html
Subsidiary external Settings command:
  • Display modal Windows form
  • Implement form validation using ErrorProvider class, Validating and Validated events
  • Store add-in option settings in XML using the .NET System.Configuration.ApplicationSettingsBase class
  • Store add-in option settings in JSON using custom solution and JavaScriptSerializer class
With visual studio the easiest thing is to use Properties -> Settings.settings from the solution explorer.
Thank you for your replies, they are very helpful!
Rail Community
