Beam/Column Faces Error
Hi All,
I'm trying to retrieve geometry data from an array of elements (walls, floors, columns and beams). When I use my algorithm with the walls and floors, there is no problem to get the Solid of the element.
Options opt = new Options();
opt.ComputeReferences = true;
foreach (Element e in listaElementos) { GeometryElement geoElement = e.get_Geometry(opt); foreach (GeometryObject obj in geoElement) { Solid geomSolid = obj as Solid; foreach (Face geomFace in geomSolid.Faces) { XYZ centroide = geomFace.Evaluate(new UV(0.5, 0.5)); // Se hace el chequeo para identificar el que está más arriba if (centroide.Z > ptoMasAlto) { puntoMasAlto = centroide; ptoMasAlto = centroide.Z; ide = e.Id; } // Se chequea cuál está más a la izquierda XYZ nuevoCentroide = new XYZ(centroide.X, centroide.Y, 0); XYZ comparacion = rle.PointOntoPlane(planoVista, nuevoCentroide); // Se compara la direccion de los vectores para obtener el que está más a la izquierda. XYZ vectorComp = (comparacion - izqPlano); double anguloComp = doc.ActiveView.RightDirection.AngleTo(vectorComp); if (Math.Abs(anguloComp - 0) > 0.1) { izqPlano = comparacion; puntoMasIzq = centroide; } } } }
But if I see what element is stored in my "listaElementos" list for beams and for columns there is a "FamilyInstance" element. Using the above code I get "null" when I ask for its solid and from then, it crashes.
Any tip of advice on how to get the faces for my columns and beams will be very appreciated.
Regards!
BardiaJahan
When you perform get_Geometry() on a family instance, it includes a GeometryInstance object instead of solid. You must retrieve that and then use GetInstanceGeometry() to get the underlying geometry. And as you notice, you can use a recursive approach - not included here - which also works for nested families.
                            ide = e.Id;
                    GeometryInstance geomInst = obj as GeometryInstance;
                    if (null != geomInst)
                        GeometryElement geoElementInst = geomInst.GetInstanceGeometry();
                        foreach (GeometryObject obj2 in geoElementInst)
Hi @BardiaJahan, thanks for your comments.
Finnally I made a Bypass like folowing:
                        // Se chequea si es un Geometry Instance (Bean Column)
                        // Caso: Beams y Columns
                        if (null == geomInst)
                                    ide = e.Id;
                            break;
I'll be attent to your comments.
Regads!
BardiaJahan
Now, does it work for walls and floors that has no GeometryInstance?
JimJia
You can try this method to get solids from base GeometryObject, hope it's helpful:
        /// <summary>
        /// Gets all solid objects from geometry object.
        /// </summary>
        /// <param name="gObj">Geometry object from where to get solids. </param>
        /// <returns>The solids of the geometry object. </returns>
        static public List<Solid> GetSolids(GeometryObject gObj)
            List<Solid> solids = new List<Solid>();
            if (gObj is Solid) // already solid
                Solid solid = gObj as Solid;
                // we don't want empty solid(face and volume is empty) here.
                if (solid.Faces.Size > 0 && Math.Abs(solid.Volume) > 0) // some solid may have not any face?!
                    solids.Add(gObj as Solid);
            else if (gObj is GeometryInstance) // find solids from GeometryInstance
                IEnumerator<GeometryObject> gIter2 = (gObj as GeometryInstance).GetInstanceGeometry().GetEnumerator();
                gIter2.Reset();
                while (gIter2.MoveNext())
                    solids.AddRange(GetSolids(gIter2.Current));
            else if (gObj is GeometryElement) // find solids from GeometryElement, this will not happen at all?
                IEnumerator<GeometryObject> gIter2 = (gObj as GeometryElement).GetEnumerator();
                gIter2.Reset();
            return solids;
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: [email protected]
