Batch process export from Revit to Navisworks
madhusudhana_rao
madhusudhana_rao
Hi All,
I am having a 4-5 revit models, at frequently I need to exported 3d views in Navisworks for clash checks.
Is there any batch process for export my Revit 3D views of each model into Navisworks as (.nwc)
It would be useful if anybody has any macro. Appreciated
Madhu
Mustafa.Salaheldin
Try to use "Batch Utility" from Navisworks and set the export settings to the 3D views you want.
See the following list: To Generate a List of All Design Files Used in the Current Model
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
madhusudhana_rao
Thanks for your prompt response.
Would Navisworks Batch utility do perform like the below items ?
a) Automatically open my Archi / Stru / M&E central models from Revit....
b) Would Go to the 3D view as specified.....
c) Export the 3d View in shared co-ordinate system....
d) save at desired folder as (.nwc)
If this works.... my issue absolutely solved.....
Thanks once again
Madhu
Mustafa.Salaheldin
Yes you can import all the trades models in one NWF file and adjust the NWC export settings to export the 3D view in each file.
¯\_(ツ)_/¯
Mustafa Salaheldin
JimJia
Revit provides Navisworks export API which can achieve your request:
. Iterate all Revit model and open it with API: Autodesk.Revit.ApplicationServices.OpenDocument(string)
. Create export option of NavisworksExportOptions
. Call Document.Export(string folder, string name, NavisworksExportOptions options);
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: [email protected]
madhusudhana_rao
I guess your response is suitable for my question...
Could you please write a small API programming code to the automation process.
Madhu
JimJia
Here is code example you can refine and run, FYI:
 public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
Application revitApp = commandData.Application.Application;
string [] files = Directory.GetFiles(@"<your folder contains rvt files>", "*.rvt", SearchOption.TopDirectoryOnly);
foreach (var file in files)
// open each rvt
Document rvtDoc = revitApp.OpenDocumentFile(file);
// find one 3d view
FilteredElementCollector coll = new FilteredElementCollector(rvtDoc);
View3D v3d = coll.OfClass(typeof(View3D)).ToElements().Cast<View3D>().Where(v => !v.IsTemplate).First();
// create export options, you may need to specify more options
NavisworksExportOptions opt = new NavisworksExportOptions();
opt.ExportScope = NavisworksExportScope.View;
opt.ViewId = v3d.Id;
// export the 3d view model to nwc
rvtDoc.Export(@"<your export folder>", rvtDoc.Title + ".nwc", opt);
rvtDoc.Close(false);
return Result.Succeeded;
Jim Jia
