Parameter
Parameter
Parameter
I have a problem to migrate an old dll to 2016 / 2017.
The problem is on this line:
Dim Sh_Data1 As Parameter = csheet.Parameter("Data")
Data is a shared parameter, on Revit 2015 work correctly, on Revit 2017 I receive this error:
Not valid CAST from "Data" string to Integer type
How I can solve it?
Mustafa.Salaheldin
Please try the Element.GetParameters Method instead.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
HI,
tahnks
can you make me a sample?
Dim Sh_Data1 As IList(Of Parameter) = csheet.GetParameters("Data")
HI,
Thanks, now work correctly, but When I use it on the current sheet, Sh_Data1 contains 2 items with the some value, why?
Mustafa.Salaheldin
This is so natural. Please read the following quote from the API guide:
"Multiple matches of parameters with the same name can occur because shared parameters or project parameters can be bound to an element category even if there is a built-in parameter with the same name already.
If this method is used to find built-in parameters the code will not be portable to other languages of Revit (because built-in parameter names are translated, and this method matches the translation).
For the reasons above this method should be used sparingly and when portability across multiple languages is not a requirement.
Safer approaches include:
  • get_Parameter(Guid) to get a shared parameter by stored guid.
  • get_Parameter(BuiltInParameter) to find a built-in parameter in a language-independent way."
¯\_(ツ)_/¯
Mustafa Salaheldin
