AYUDA!!! QUIERO INSTALAR BIM REVIT PERO APARECE ESTE ERROR
https://snipboard.io/tHNmBr.jpg
Muy buenos días para todos, he intentado descargar BIM REVIT por dos días y no lo he podido instalar, me aparece el error que aparece en esa imagen que les compartí, podría alguien ayudarme? se los agradeceré muchísimo.
jeremytammik
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to licensing and installation.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
P.S. Writing in all upper case is considered impolite.
No offense meant or taken, just pointing out:
https://www.lifewire.com/why-not-to-write-in-all-caps-1173242
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
