Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Automate Dynamo-Script
1 REPLY 1
timosmd
499 Views, 1 Reply
I hope this is the correct forum for my question.
for my project I need to create a 3D-Printing Slicer for a 6 axis robot arm and found the following tutorial which I think is possible to be modified to suit my needs:
https://www.instructables.com/How-to-Build-Your-Own-3D-Printing-Slicer-From-Scra/
The problem is that the script I will be creating with Dynamo needs to be fully automated and for example be executed from a C++ script/command line.
So the workflow I am thinking of is:
1. Execute Dynamo-Script by calling it from a C++ Application (for example)
2. Dynamo-Script imports 3D-Model
3. Dynamo-Script is Slicing the Model into different Layers (not only 2 dimensional)
4. Dynamo-Script outputs the layer information to be accessible by C++ Application
5. C++ Application performs inverse Kinematics on the layer/toolpath-Information to create a robot program
Do you think this is somehow possible? I couldn't find much information online to automate dynamo-script.
Thanks in advance!
Tags (1)
1 REPLY 1
jeremytammik
in reply to: timosmd
No, sorry, you are not in the right place.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Your question has nothing whatsoever to do with Revit or its API.
Your question seems Dynamo-related to me.
Therefore, you may have better luck discussing it in the Dynamo forum:
https://forum.dynamobim.com
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
