Autodesk Supported Graphics Hardware
We are speccing new PCs now and have just taken a look here and
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112&
If I select Graphics Hardware, AutoCAD, 2018, Windows 10 64-bit and then Graphics Card Manufacturer and NVIDIA. I get a list of approved NVIDIA Cards.
If I do the same for Revit 2017 and AutoCAD 2017 I get a list of approved NVIDIA cards.
If I select Revit 2018 though it only shows AMD cards.
My boss is looking at new NVIDIA cards. Presumably, the issue is AutoDESK have either not tested or updated this location for NVIDIA cards but I guess there is a chance they are not certifying NVIDIA cards. That would be potentially a major hiccup at our end. Do you have any idea what is going on?
jeremytammik
Dear Gurvinder,
Thank you for your query.
All I can do for you right here and now is point to the Revit 2018 system requirements:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
For more in-depth installation information, unfortunately, you are in the wrong forum here.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
