Autodesk . Revit DB Rectangle rect = UIView . GetWindowRectangle ();
I try the code " Autodesk . Revit .DB .Rectangle rect = UIView . GetWindowRectangle (); " in Revit 2017 . I got the error " CS0120 An object reference is required for the non-static field , method ,or property 'UIView . GetWindowRectangle () ' " . How to cure it ? Any help will appreciate .
I know  Rectangle class  have moved from the UI namespace in the Revit 2015 and 2016 APIs to DB in Revit 2017:
FAIR59
you need a UIView object for the method to work.
            IList<UIView> _uiViews = commandData.Application.ActiveUIDocument.GetOpenUIViews();
            UIView _uiViewAct = null;
            foreach (UIView _uiview in _uiViews )
                if (_uiview.ViewId == document.ActiveView.Id)
                    _uiViewAct = _uiview;
                    break;
            Autodesk.Revit.DB.Rectangle rect =  _uiViewAct.GetWindowRectangle();
Thank FAIR59,I still got error
FAIR59
In the References section (Visual Studio) you most likely have loaded the 2016 RevitAPI.dll and RevitAPIUI.dll
if you want to compile for 2017 change the dll's for the 2017 version.
if you want to compile for 2016
 change the code to
Autodesk.Revit.UI.Rectangle rect = _uiViewAct.GetWindowRectangle();
Thank FAIR59 , I really make this mistake , It can work , thank very much .
