Auto-Filling Identity Data as I draw....
As I draw fabrication parts I would like to be able to Auto-Fill two of these fields. Does anyone have any ideas on how to do this? I am suspect that I will need to toy with the Revit API on this one. Which is why I'm posting here. I guess the question would be, CAN I do this with a script in the API?
adam.krug
If you mean some parameter values under "Identity Data" group then yes, it should be possible with Revit API. You could do it with the built-in macro manager or build your own add-on. I assume you could also do it with Revit Python Shell.
To do it on the fly you'd need to subscribe to the DocumentChanged event, from its DocumentChangedEventArgs you have to extract the list of new elements, filter it to see only the stuff you want to set the parameter values for, set the parameter values in a transaction and that's it.
Ok, that's what I was thinking as well. With that, would it be automatic? Meaning, could I write a small plug-in where I typed in the information I wanted to be filled. Then I drew a bunch, and those fields would be automatically filled based of off what I put into my plug-in?
adam.krug
Actually, I now rethought it. I believe you couldn't use macro manager for it, but you could make your own plug-in. You need to implement the solution described in the below article.
http://thebuildingcoder.typepad.com/blog/2016/11/using-other-events-to-execute-add-in-code.html
JimJia
Thanks for sharing!
Yet another approach is to use DMU(Dynamic Model Updater):
http://thebuildingcoder.typepad.com/blog/2016/01/idling-dmu-documentchanged-and-need-for-regen.html
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
adam.krug
This sounds much better indeed. I need to try it too.
adam.krug
Is it possible to implement DMU in macro manager? I'm just curious.
